Thanks, your idea looks very good for me.
But I use AUTOCAD 2006, when I open the Layer translator dialog box, (please see attacehd screen shot), I can't find anyplace can load up the "Layer Translations" dialog box, and I don't know where can I set up the layer templates.
For me, I hope can change layer name and linetype together, because we start use new standard layer system, we need change about 40 layer name to new name, and most of the old layers linetype is good, I don't need change, I have 5 old layer's linetype need change to new linetype. I devide the process to step is because someone told me can't do those things onece time. If you can find we help me do all the things toghether, that's will be great.
Right now, I just use the LISP rename the layers, then use check standard to change linetype, afterthat , munully put linetype scale for different Model/Paper space.
Thank very much for your help!
