.NET
mutiple Thread in CAD command!
4 REPLIES 4
671 Views, 4 Replies
Hi,guys.I want using mutiple threads to operate CAD. But See code below.
Imports Autodesk.AutoCAD.Runtime
Imports qApp = Autodesk.AutoCAD.ApplicationServices
'System ref
Imports Autodesk.AutoCAD.Interop
Imports System.Windows.Forms
Imports System.Windows.Forms.Integration
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports System.Text.RegularExpressions
Imports Seg_CADCommon.SegCommon.CAD
Imports System.Threading
      Dim  t As Thread
  Public Sub Gettid()
            Dim doc As qApp.Document = qApp.Application.DocumentManager.MdiActiveDocument
            MsgBox(doc Is Nothing)
            ' operate.Textptid.GetTid(True, doc, Mpttextlist)
        End Sub
        <CommandMethod("Ststart", CommandFlags.Session)> _
        Public Sub Ststart()
            Try
                t = New Thread(AddressOf Gettid)
                t.Start()
            Catch
            End Try
        End Sub
        <CommandMethod("Stabort", CommandFlags.Session)> _
        Public Sub Stabort()
            Try
                t.Abort()
            Catch
            End Try
        End Sub
        <CommandMethod("Stmessg", CommandFlags.Session)> _
        Public Sub Stmessg()
            Try
                'qApp.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(Mpttextlist.Count)
            Catch
            End Try
        End Sub
 But When I Start the thread. It tells me that doc is nothing. You can Test it. I don't understand why doc is nothing. I want use the doc in this thread.
Thank you in advance.
4 REPLIES 4
for long times it sees that AutoCAD could not support the MultiThread, if it can, sorry for my ignorance.
while that's what seems to be the general consensus (no multi-threading in acad plugins) I found that it is possible to have acad objects shared between threads.  Check out the following discussion: I posted a solution at end of it.  It also has links that might help in your case as well.
http://forums.autodesk.com/t5/NET/Catastrophic-failure-HRESULT-0x8000FFFF-E-UNEXPECTED/m-p/3765575#M...
dgorsman
What, precisely, do you need multi-threading capability for?
Thank for you advise
”Boost
