.NET
mutiple Thread in CAD command!
4 REPLIES 4
huaxiamengqing
669 Views, 4 Replies
Hi,guys.I want using mutiple threads to operate CAD. But See code below.
Imports Autodesk.AutoCAD.Runtime
Imports qApp = Autodesk.AutoCAD.ApplicationServices
'System ref
Imports Autodesk.AutoCAD.Interop
Imports System.Windows.Forms
Imports System.Windows.Forms.Integration
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports System.Text.RegularExpressions
Imports Seg_CADCommon.SegCommon.CAD
Imports System.Threading
      Dim  t As Thread
  Public Sub Gettid()
            Dim doc As qApp.Document = qApp.Application.DocumentManager.MdiActiveDocument
            MsgBox(doc Is Nothing)
            ' operate.Textptid.GetTid(True, doc, Mpttextlist)
        End Sub
        <CommandMethod("Ststart", CommandFlags.Session)> _
        Public Sub Ststart()
            Try
                t = New Thread(AddressOf Gettid)
                t.Start()
            Catch
            End Try
        End Sub
        <CommandMethod("Stabort", CommandFlags.Session)> _
        Public Sub Stabort()
            Try
                t.Abort()
            Catch
            End Try
        End Sub
        <CommandMethod("Stmessg", CommandFlags.Session)> _
        Public Sub Stmessg()
            Try
                'qApp.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(Mpttextlist.Count)
            Catch
            End Try
        End Sub
 But When I Start the thread. It tells me that doc is nothing. You can Test it. I don't understand why doc is nothing. I want use the doc in this thread.
Thank you in advance.
4 REPLIES 4
in reply to: huaxiamengqing
for long times it sees that AutoCAD could not support the MultiThread, if it can, sorry for my ignorance.
sszabo
while that's what seems to be the general consensus (no multi-threading in acad plugins) I found that it is possible to have acad objects shared between threads.  Check out the following discussion: I posted a solution at end of it.  It also has links that might help in your case as well.
http://forums.autodesk.com/t5/NET/Catastrophic-failure-HRESULT-0x8000FFFF-E-UNEXPECTED/m-p/3765575#M...
dgorsman
What, precisely, do you need multi-threading capability for?
huaxiamengqing
in reply to: sszabo
Thank for you advise
”Boost
