Hi! I have (probably) a very basic question - is it possible to figure out what code should I write to access certain classes/objects/properties etc using object browser? For example, if I write:
Document MyDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
then MdiActiveDocument is available "under" Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager. However If I browse to DocumentManager using ObjectBrowser then it is represented with a property icon and there is nothing that indicates (to me) that I might access MidActiveDocument from there. If I browse to Autodesk.AutoCAD.ApplicationServices.DocumentCollection I will find that MdiActiveDocument resides there. However I will not be able to access it by writing corresponding code:
What I wonder is - is there any use of ObjectBrowser when working with Autocad API? I have seen in other examples how does one access MdiActiveDocument in his/her code but I can not understand why. Is there any way to "reconstruct" this logic or it is just the way it is? Thanks in advance!
