Hi Guys,
please I did batch plot using C# I use specific plot style name, but I want to load the plot styles in the storred path on the server into a ListBox.
please see the image attached.
thank you very much
Solved by norman.yuan. Go to Solution.
You can use COM API AcadPreferencesFiles.PrinterStyleSheetPath to get the folder path where *.ctb files are located.
If you use .NET 4, you can use dynamic without having to add reference to AutoCAD COM API interop:
C# code would be like:
dynamic cadPreferences=Application.Preference;
string folder=cadPreferences.PrinterStyleSheetPath;
string[] ctbFiles=System.IO.Directory.GetFiles(folder, "*.ctb");
Then you can use the file name array to populate listbox.
Norman Yuan
