Is it possible to distinguish whether a Layout is empty or not?
I need to check this routine in plenty of drawing, so please tell me some easy way to find empty layout.
Thanks in advance,
thenndral
Solved by thenndral. Go to Solution.
Solved by _gile. Go to Solution.
You may need iterate through the BlockTableRecord of each layout to find whether it contains any objects.
Thanks _gile for an awesome code.
May be this code will helpful for someone.
Document doc = AcAp.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; using (Transaction tr = db.TransactionManager.StartTransaction()) { var layouts = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead); foreach (var entry in layouts) { var layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead); var btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead); ed.WriteMessage("\n{0} contains {1} ObjectId.", layout.LayoutName, btr.Cast<ObjectId>().Count()); } tr.Commit(); }
Thanks again,
thenndral
