.NET
Stand-alone VB.NET program to create simple drawing
3 REPLIES 3
508 Views, 3 Replies
Hello All,
I'm new to automation of AutoCAD. I've fruitlessly searched high and low for an example of how to connect to AutoCAD and create some simple drawing entities from a stand-alone VB.NET (2008) program. All examples I see are of utilities that are imported into AutoCAD and used within the parent application.
From the click of a button on a form, I wish to open a visible instance of AutoCAD and create a spline and a series of reference circles (dimensions can be hard-coded to start out). If anyone can point me to a simple sample app that demonstrates how to accomplish some of these tasks, I would greatly appreciate it.
Best regards,
John
3 REPLIES 3
Your best bet would be to ask in the VBA newsgroup, because from another
process, you must use the ActiveX API to control AutoCAD. Also look for
examples using a VB6-based standalone process.
This newsgroup focuses on the managed API for AutoCAD, which cannot be used
from another process.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6297526@discussion.autodesk.com...
Hello All,
application.
appreciate it.
Best regards,
John
Thanks for your reply, Tony. By "VBA newsgroup", are you referring to the "Visual Basic Customization" forum?
http://discussion.autodesk.com/forums/forum.jspa?forumID=33
Yes.
”Boost
