Your best bet would be to ask in the VBA newsgroup, because from another
process, you must use the ActiveX API to control AutoCAD. Also look for
examples using a VB6-based standalone process.
This newsgroup focuses on the managed API for AutoCAD, which cannot be used
from another process.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6297526@discussion.autodesk.com...
Hello All,
I'm new to automation of AutoCAD. I've fruitlessly searched high and low for
an example of how to connect to AutoCAD and create some simple drawing
entities from a stand-alone VB.NET (2008) program. All examples I see are of
utilities that are imported into AutoCAD and used within the parent
application.
From the click of a button on a form, I wish to open a visible instance of
AutoCAD and create a spline and a series of reference circles (dimensions
can be hard-coded to start out). If anyone can point me to a simple sample
app that demonstrates how to accomplish some of these tasks, I would greatly
appreciate it.
Best regards,
John
