I think you may need a little more background on WPF, the
ListView, and using XAML to bind to data. It does work if
done correctly.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6298516@discussion.autodesk.com...
Thanks for the reply, Tony.
I got the columns defined ok, but it is how to add the data.
I have tried to define an ArrayList in code by defining a class of data
variables. I then link the ArrayList to the ListView using .ItemsSource.
But I get blank rows with no data ...
I just wondered if anyone had been successful in filling a ListView at
runtime with data in a Grid format?
