Greetings to all,
Here i have one question...
Is that possible to read the Autocad Table data , without opening the Autocad from VB.NET.
I tried with opening one autocad then loading the source dll. it was working perfectly.
but i need to without opening a application its possible or not?
Thanks in advance.
You could do this if you licensed RealDWG (www.autodesk.com/realdwg). But the public (free) AutoCAD APIs require you have AutoCAD installed on your computer (and running).
In addition to Stephens comment, you could use a COM application which would require you to open AutoCAD, but you could open it Invisibly, so the user doesn't see it open. That's as close as you can get, without using RealDWG.
Hey Ranjith, did you get any success in doing so. Because i am also looking for some similar kind of solution. Can you post it here if you have any
Hi amit,
What kind of solution you are looking for? Can you please explain?
If you want to start AutoCAD from a external application using ActiveX API, then refer http://through-the-interface.typepad.com/through_the_interface/2007/12/launching-autoc.html & http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
If you're still using COM, so try this code,
not tested seriously, just the same logic
as I'm posted before,
change file name you'll want to open
Public Shared Sub ReadTableFromDwg() Dim acadver As String = "18" '//AutoCAD Version ' set your file name to read data here Dim fname As String = "C:\Test\mtext.dwg" ' define csv file name variable Dim csvname As String = String.Empty Dim listData As New List(Of Object) ' get current culture Dim oldCult As System.Globalization.CultureInfo = System.Threading.Thread.CurrentThread.CurrentCulture ' create new culture Dim thisCult As System.Globalization.CultureInfo = New System.Globalization.CultureInfo("en-US") ' set current culture to newly created System.Threading.Thread.CurrentThread.CurrentCulture = thisCult MsgBox("Wait...") Dim appProgID As String = "Autocad.Application" + "." + acadver ' get reference on interface IDispatch Dim AcadType As Type = Type.GetTypeFromProgID(appProgID) ' launch AutoCAD Dim AcadApp As Object = Activator.CreateInstance(AcadType) Dim visargs() As Object = New Object(0) {} ' set visibility mode to false visargs(0) = True ' Make application visible AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, AcadApp, visargs, Nothing) ' Maximize window ''AcadApp.GetType().InvokeMember("WindowState", BindingFlags.SetProperty, Nothing, AcadApp, New Object() {1}, Nothing) Dim AcadDocs As Object = AcadApp.GetType().InvokeMember("Documents", BindingFlags.GetProperty, Nothing, AcadApp, Nothing) ' define arguments to open file Dim args() As Object = New Object(1) {} args(0) = fname ' set read only mode to false args(1) = False ' try open document Dim AcDoc As Object = AcadDocs.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing) Dim AcUtil As Object = New Object Try ' get reference on active document AcDoc = AcadApp.GetType().InvokeMember("ActiveDocument", BindingFlags.GetProperty, Nothing, AcadApp, Nothing, Nothing) ' get reference on ModelSpace Dim AcSpace As Object = AcDoc.GetType().InvokeMember("ModelSpace", BindingFlags.GetProperty, Nothing, AcDoc, Nothing) ' get reference of AcadUtility AcUtil = AcDoc.GetType().InvokeMember("Utility", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, AcDoc, Nothing) Dim acTable As New Object ' '_____________________________________________ ' ' based on example written by Tony Tanzillo ' '_____________________________________________ ' The array of arguments that will be passed ' to the AcadUtil.GetEntity() method: Dim entargs As Object() = New Object(2) {} ' In order to get VT_BYREF arguments to be ' filled in by the callee, we must use ParameterModifier ' to retrieve the arguments: ' The callee will replace the ParameterModifier ' in the args[] argument array with the results. entargs(0) = New Object entargs(1) = New Object entargs(2) = vbLf + "! Select Table !" ' We also need to tell the marshaler that ' both parameters in the COM method call are ' 'out' or 'byref' parameters: ' 2 = the total number of arguments passed: Dim pm As New ParameterModifier(3) pm(0) = True ' first argument is ByRef pm(1) = True ' second argument is ByRef pm(1) = False ' third argument is ByVal Dim modifiers As ParameterModifier() = New ParameterModifier() {pm} ' Invoke the method, passing the arguments, and ' the parameter modifers AcUtil.GetType().InvokeMember("GetEntity", BindingFlags.InvokeMethod, Nothing, AcUtil, entargs, modifiers, Nothing, Nothing) ' The results are now in the entargs[] array: Dim entity As Object = DirectCast(entargs(0), Object) Dim pickpt As Object = DirectCast(entargs(1), Object) Dim objName As String = entity.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty Or BindingFlags.IgnoreCase, Nothing, entity, Nothing).ToString() ' make sure the table object selected If objName <> "AcDbTable" Then MessageBox.Show("Selectet is not type of table, exit program ...") Return End If acTable = entity Dim tableRows As Object = acTable.GetType().InvokeMember("Rows", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, acTable, Nothing) Dim tableColumns As Object = acTable.GetType().InvokeMember("Columns", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, acTable, Nothing) Dim tableContent As New List(Of List(Of String)) For i As Integer = 0 To tableRows - 1 Dim tableLine As New List(Of String) For j As Integer = 0 To tableColumns - 1 Dim cellText As Object = acTable.GetType().InvokeMember("GetText", BindingFlags.InvokeMethod Or BindingFlags.Public, Nothing, acTable, New Object() {i, j}) tableLine.Add(cellText.ToString()) Next tableContent.Add(tableLine) Next ''-------------------------------------------------'' '' for debug only: 'Dim sb As New StringBuilder 'For Each line As List(Of String) In tableContent ' Dim textline As String = "" ' For Each st As String In line ' textline = textline + st + vbTab ' Next ' sb.AppendLine(textline.TrimEnd(vbTab)) 'Next 'MessageBox.Show(sb.ToString()) ''-------------------------------------------------'' Dim initDir As String = AcDoc.GetType.InvokeMember("Path", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing).ToString() Dim saveFileDialog As New System.Windows.Forms.SaveFileDialog saveFileDialog.Title = "Enter a file name to write data: " saveFileDialog.InitialDirectory = initDir saveFileDialog.RestoreDirectory = True saveFileDialog.Filter = "CSV files | *.csv" saveFileDialog.FileName = "File name without extension" Dim result As System.Windows.Forms.DialogResult = saveFileDialog.ShowDialog() If result <> DialogResult.OK Then csvname = "Not saved" Return End If csvname = saveFileDialog.FileName ' Write data to CSV Using sw As New StreamWriter(csvname, True, Encoding.ASCII) For Each line As List(Of String) In tableContent Dim textline As String = "" For Each st As String In line textline = textline + st + vbTab Next sw.WriteLine(textline.TrimEnd(vbTab)) Next End Using ''----------------------------------------------------------------------------------------------------'' 'save document Dim closeargs() As Object = New Object(1) {} closeargs(0) = True ' with the same name closeargs(1) = fname ' Try close document ' simplified syntax AcDoc.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, Nothing, AcDoc, closeargs) Catch ex As System.Exception MessageBox.Show("Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace) Finally ' Try quit application AcadApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing) ' clean up the memory '--------------------' ' release Document. releaseObject(AcDoc) ' release Documents. releaseObject(AcadDocs) ' release Application. releaseObject(AcadApp) ' call garbage cleaner immediatelly GC.WaitForPendingFinalizers() GC.GetTotalMemory(True) GC.WaitForPendingFinalizers() GC.GetTotalMemory(True) ' restore current culture System.Threading.Thread.CurrentThread.CurrentUICulture = oldCult 'Display result MessageBox.Show("Csv file saved as:" + vbLf + csvname) End Try End Sub
~'J'~
I have seen your posts so for.
I am facing a problem in reading the table from autocad document.
Can you share your code.
That could be helpful.
Thanks and regards,
D.Giridhar
I don't have the code and going by concept.
Reading table is straight forward approach
