.NET
Reading data from autocad table
10 REPLIES 10
Message 1 of 11
2082 Views, 10 Replies
Greetings to all,
Here i have one question...
Is that possible to read the Autocad Table data , without opening the Autocad from VB.NET.
I tried with opening one autocad then loading the source dll. it was working perfectly.
but i need to without opening a application its possible or not?
Thanks in advance.
10 REPLIES 10
Message 2 of 11
StephenPreston
You could do this if you licensed RealDWG (www.autodesk.com/realdwg). But the public (free) AutoCAD APIs require you have AutoCAD installed on your computer (and running).
Cheers,
Stephen Preston
Autodesk Developer Network
Message 3 of 11
chiefbraincloud
In addition to Stephens comment, you could use a COM application which would require you to open AutoCAD, but you could open it Invisibly, so the user doesn't see it open.  That's as close as you can get, without using RealDWG.
Message 4 of 11
Thank u so much,
Cheers,
Ranjith
Message 5 of 11
amitnkukanur
Hey Ranjith, did you get any success in doing so. Because i am also looking for some similar kind of solution. Can you post it here if you have any
Senior Software Engineer
Message 6 of 11
Hi amit,
What kind of solution you are looking for? Can you please explain?
If you want to start AutoCAD from a external application using ActiveX API, then refer http://through-the-interface.typepad.com/through_the_interface/2007/12/launching-autoc.html & http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
Virupaksha Aithal KM
Developer Technical Services
Message 7 of 11
Hallex
in reply to: amitnkukanur
If you're still using COM, so try this code,
not tested seriously, just the same logic
as I'm posted before,
change file name you'll want to open
    Public Shared Sub ReadTableFromDwg()
        Dim acadver As String = "18" '//AutoCAD Version
        ' set your file name to read data here
        Dim fname As String = "C:\Test\mtext.dwg"
        ' define csv file name variable
        Dim csvname As String = String.Empty
        Dim listData As New List(Of Object)
        ' get current culture
        Dim oldCult As System.Globalization.CultureInfo = System.Threading.Thread.CurrentThread.CurrentCulture
        ' create new culture
        Dim thisCult As System.Globalization.CultureInfo = New System.Globalization.CultureInfo("en-US")
        ' set current culture to newly created
        System.Threading.Thread.CurrentThread.CurrentCulture = thisCult
        MsgBox("Wait...")
        Dim appProgID As String = "Autocad.Application" + "." + acadver
        ' get reference on interface IDispatch
        Dim AcadType As Type = Type.GetTypeFromProgID(appProgID)
        ' launch AutoCAD
        Dim AcadApp As Object = Activator.CreateInstance(AcadType)
        Dim visargs() As Object = New Object(0) {}
        ' set visibility mode to false
        visargs(0) = True
        ' Make application visible
        AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, AcadApp, visargs, Nothing)
        ' Maximize window
        ''AcadApp.GetType().InvokeMember("WindowState", BindingFlags.SetProperty, Nothing, AcadApp, New Object() {1}, Nothing)
        Dim AcadDocs As Object = AcadApp.GetType().InvokeMember("Documents", BindingFlags.GetProperty, Nothing, AcadApp, Nothing)
        ' define arguments to open file
        Dim args() As Object = New Object(1) {}
        args(0) = fname
        ' set read only mode to false
        args(1) = False
        ' try open document
        Dim AcDoc As Object = AcadDocs.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing)
        Dim AcUtil As Object = New Object
        Try
            ' get reference on active document
            AcDoc = AcadApp.GetType().InvokeMember("ActiveDocument", BindingFlags.GetProperty, Nothing, AcadApp, Nothing, Nothing)
            ' get reference on ModelSpace
            Dim AcSpace As Object = AcDoc.GetType().InvokeMember("ModelSpace", BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
            ' get reference of  AcadUtility
            AcUtil = AcDoc.GetType().InvokeMember("Utility", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, AcDoc, Nothing)
            Dim acTable As New Object
            '        '_____________________________________________
            '        ' based on example written by Tony Tanzillo
            ' The array of arguments that will be passed
            ' to the AcadUtil.GetEntity() method:
            Dim entargs As Object() = New Object(2) {}
            ' In order to get VT_BYREF  arguments to be
            ' filled in by the callee, we must use ParameterModifier
            ' to retrieve the arguments:
            ' The callee will replace the ParameterModifier
            ' in the args[] argument array with the results.
            entargs(0) = New Object
            entargs(1) = New Object
            entargs(2) = vbLf + "! Select Table !"
            ' We also need to tell the marshaler that
            ' both parameters in the COM method call are
            ' 'out' or 'byref' parameters:
            ' 2 = the total number of arguments passed:
            Dim pm As New ParameterModifier(3)
            pm(0) = True
            ' first argument is ByRef
            pm(1) = True
            ' second argument is ByRef
            pm(1) = False
            ' third argument is ByVal
            Dim modifiers As ParameterModifier() = New ParameterModifier() {pm}
            ' Invoke the method, passing the arguments, and
            ' the parameter modifers
            AcUtil.GetType().InvokeMember("GetEntity", BindingFlags.InvokeMethod, Nothing, AcUtil, entargs, modifiers, Nothing, Nothing)
            ' The results are now in the entargs[] array:
            Dim entity As Object = DirectCast(entargs(0), Object)
            Dim pickpt As Object = DirectCast(entargs(1), Object)
            Dim objName As String = entity.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty Or BindingFlags.IgnoreCase, Nothing, entity, Nothing).ToString()
            ' make sure the table object selected
            If objName <> "AcDbTable" Then
                MessageBox.Show("Selectet is not type of table, exit program ...")
                Return
            End If
            acTable = entity
            Dim tableRows As Object = acTable.GetType().InvokeMember("Rows", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, acTable, Nothing)
            Dim tableColumns As Object = acTable.GetType().InvokeMember("Columns", BindingFlags.GetProperty Or BindingFlags.Public, Nothing, acTable, Nothing)
            Dim tableContent As New List(Of List(Of String))
            For i As Integer = 0 To tableRows - 1
                Dim tableLine As New List(Of String)
                For j As Integer = 0 To tableColumns - 1
                    Dim cellText As Object = acTable.GetType().InvokeMember("GetText", BindingFlags.InvokeMethod Or BindingFlags.Public, Nothing, acTable, New Object() {i, j})
                    tableLine.Add(cellText.ToString())
                Next
                tableContent.Add(tableLine)
            Next
            '' for debug only:
            'Dim sb As New StringBuilder
            'For Each line As List(Of String) In tableContent
            '    Dim textline As String = ""
            '    For Each st As String In line
            '        textline = textline + st + vbTab
            '    Next
            '    sb.AppendLine(textline.TrimEnd(vbTab))
            'Next
            'MessageBox.Show(sb.ToString())
            Dim initDir As String = AcDoc.GetType.InvokeMember("Path", BindingFlags.GetProperty, Nothing, AcDoc, Nothing, Nothing).ToString()
            Dim saveFileDialog As New System.Windows.Forms.SaveFileDialog
            saveFileDialog.Title = "Enter a file name to write data: "
            saveFileDialog.InitialDirectory = initDir
            saveFileDialog.RestoreDirectory = True
            saveFileDialog.Filter = "CSV files | *.csv"
            saveFileDialog.FileName = "File name without extension"
            Dim result As System.Windows.Forms.DialogResult = saveFileDialog.ShowDialog()
            If result <> DialogResult.OK Then
                csvname = "Not saved"
                Return
            End If
            csvname = saveFileDialog.FileName
            ' Write data to CSV
            Using sw As New StreamWriter(csvname, True, Encoding.ASCII)
                    Next
                    sw.WriteLine(textline.TrimEnd(vbTab))
                Next
            End Using
            'save document
            Dim closeargs() As Object = New Object(1) {}
            closeargs(0) = True
            ' with the same name
            closeargs(1) = fname
            ' Try close document
            ' simplified syntax
            AcDoc.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, Nothing, AcDoc, closeargs)
        Catch ex As System.Exception
            MessageBox.Show("Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace)
        Finally
            ' Try quit application
            AcadApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing)
            ' clean up the memory
            ' release Document.
            releaseObject(AcDoc)
            ' release Documents.
            releaseObject(AcadDocs)
            ' release Application.
            releaseObject(AcadApp)
            ' call garbage cleaner immediatelly
            GC.WaitForPendingFinalizers()
            GC.GetTotalMemory(True)
            ' restore current culture
            System.Threading.Thread.CurrentThread.CurrentUICulture = oldCult
            'Display result
            MessageBox.Show("Csv file saved as:" + vbLf + csvname)
        End Try
    End Sub
~'J'~
Message 8 of 11
dudde.giridhar
I have seen your posts so for.
I am facing a problem in reading the table from autocad document.
Can you share your code.
That could be helpful.
Thanks and regards,
D.Giridhar
Message 9 of 11
I don't have the code and going by concept.
Reading table is straight forward approach
Message 10 of 11
hosneyalaa
in reply to: dudde.giridhar
Message 11 of 11
dudde.giridhar
in reply to: hosneyalaa
Dear  hosneyalaa,
Thanks for the replay.
I will go through that and come back.
D.Giridhar.
”Boost
