Hello All,
I am using AutoCAD 2006 and Visual Studio 2005 with VB.Net. I have a subroutine to create a layer, it works fine except that for some reason the description field does not work. Whatever value I pass in on description it fails to be applied to the layer, here is my code:
Public Sub MakeLayer(ByVal LayerName As String, ByVal Colour As Int16, _
ByVal LineType As String, Optional ByVal Description As String = "")
Dim layerId As ObjectId 'the return value for this function
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim trans As Transaction = db.TransactionManager.StartTransaction()
'Get the layer table first...
Try
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForWrite)
'Check if Layer exists...
If lt.Has(LayerName) Then
layerId = lt.Item(LayerName)
Else
'If not, create the layer here.
Dim ltr As LayerTableRecord = New LayerTableRecord()
ltr.Name = LayerName
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, Colour)
If LineType <> "Continuous" Then
ltr.LinetypeObjectId = CheckForLineType(LineType)
End If
ltr.Description = Description
layerId = lt.Add(ltr)
trans.AddNewlyCreatedDBObject(ltr, True)
End If
trans.Commit()
Catch aex As Autodesk.AutoCAD.Runtime.Exception
MsgBox("AutoCAD Exception (MAKELAYER): " & aex.Message, MsgBoxStyle.Exclamation)
Catch ex As System.Exception
MsgBox("System Exception: " & ex.Message, MsgBoxStyle.Exclamation)
Finally
trans.Dispose()
End Try
End Sub
Can anybody please explain what is going on here, thanks in advance for any advice you can offer.
Kind Regards,
Martin.
