.NET
Solid3D IntersectWith problem
2 REPLIES 2
hericson
697 Views, 2 Replies
I want to check if two Solid3D entities intersect with each other. But the function IntersectWith is not yet implemented!
Any ideas how to solve my problem?
2 REPLIES 2
hgasty1001
in reply to: hericson
You can check if 2 solid intersect using check interference: MySolid.CheckInterference(TheOtherSolid)
Gaston Nunez
hericson
in reply to: hgasty1001
Thanks a lot! So simple then you know it!
”Boost
