If you can, try a non-obsfucated version of your app
on the problem system, to see if the obsfucation has
any role.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6400340@discussion.autodesk.com...
I have a net dll, which has been developed with visual studio 2005, language
vb.net, obfuscated/optimized with smartassembly.
It is loaded into autocad with the netload command.
So far it had worked perfectly in about 12 customers. Some customers had autocad
2008, others had autocad 2009 or 2010. I think all had windows vista. It worked
perfectly with all customers.
Now I tried it on a new customer who has windows 7 64 bits. First we tried with
autocad 2008. It did not work so we installed autocad 2009. It did not work
either.
You can load it with the netload command but it does absolutely nothing, it
gives no errors but does absolutely nothing when you type the commands. Commands
are not recognized and it does not change the default system menu in autocad.
Please Help
Jose Maria
