Gentlemen, I need to create some complex curved 3D Faces with the .NET API however I have never done it before so I am unsure where to start. I have a series of points that I can connect with lines/arcs to create the outline of a curved 3D Face. How can I create a 3D face with these points? Can someone point me in the right direction or possibly link me some sample code?
EDIT:
It doesnt have to be a face. It can be any solid surface.
I have attached an image to hopefully better describe what I am trying to accomplish. The circles represent Point3d References. The lines and arcs represent the boundry of the curved face I am trying to create via the .NET API. The shape is not planar, and it cannot be swept or extruded because of it's shape. I feel like the first step would be to create a closed boundry using the points, but I am not sure which classes/methods to use.
That surface looks like a rulesurf (check for rulesurf command, and also tabsurf and edgesurf out in the Autocad help), but i'm not sure if a rulesurf can be created with a lofted surface (i'm not sure if a lofted surface can be mathematically equivalent to a rulesurf). But lofted surface can be created with the API, see this link Lofted Surfaces
Gaston Nunez
Another way is using command edgesurf, tested in A2014:
'ads_queueexpr ' A2010 <DllImport("acad.exe", CharSet:=CharSet.Unicode, CallingConvention:=CallingConvention.Cdecl, EntryPoint:="ads_queueexpr")> _ Private Shared Function ads_queueexpr(command As Byte()) As Integer End Function ' A2014 '<DllImport("accore.dll", CharSet:=CharSet.Unicode, CallingConvention:=CallingConvention.Cdecl, EntryPoint:="ads_queueexpr")> _ ''____________________________________________________________________ #Region "command Edgesurf" <CommandMethod("loope")> _ Public Sub LoopGetEntity() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim hnds() As String = GetObjectHandles(doc, "Select curve: ") ed.Regen() Using tr As Transaction = doc.Database.TransactionManager.StartTransaction() Dim uEncode As New UnicodeEncoding() ads_queueexpr(uEncode.GetBytes("(Command ""_.edgesurf""" & "(handent " & """" & hnds(0) & """" & ")" _ & "(handent " & """" & hnds(1) & """" & ")" & _ "(handent " & """" & hnds(2) & """" & ")" _ & "(handent " & """" & hnds(3) & """" & ")" & vbCr & ")")) End Using End Sub Private Shared Function GetObjectHandles(ByVal doc As Document, msg As String) As String() Dim ids As New List(Of ObjectId) Dim hnds As New List(Of String) Using tr As Transaction = doc.Database.TransactionManager.StartTransaction() Dim go As Boolean = True While go go = False Dim opt As New PromptEntityOptions(vbLf & msg) Dim res As PromptEntityResult = doc.Editor.GetEntity(opt) If res.Status = PromptStatus.OK Then Dim exists As Boolean = False For Each id As ObjectId In ids If id = res.ObjectId Then exists = True Exit For End If Next If Not exists Then 'Highlight Dim ent As Entity = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForWrite), Entity) Dim strhandle As String = ent.Handle.ToString() ent.Highlight() hnds.Add(strhandle) ids.Add(res.ObjectId) If hnds.Count > 4 Then go = False go = True End If End If End While tr.Commit() End Using Return hnds.ToArray() End Function #End Region
