I need to convert some 2d drawings into 3D automically. Can anyone suggest me how can I start to do so using .NET API. Below is the screen shot of the 2d drawing. I have also attached the drawing. any sample code would be helpful for me.
The stated work process is backwards to the normal design procedures - parts are designed in 3D and drawings are derived from the model, not the other way around.
If this is strictly for IC work, look up industry standards - there are a limited range of pin sizes, spacings, and counts such that you could easily create a small library to work from.
