• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Civil 3D 2012 Install error - not available for select language
    147 Views, 5 Replies
    01-07-2013 01:24 PM
    An end user had a hard drive failure recently.  On a fresh drive, installed Win7 x64 (pro).  First piece of software (after driver installation) that I installed was our Design Suite Premium 2012.  All software items show that they will install except for Civil 3D.  It has a small red X next to it, stating "This product or its prerequisites do not support currently selected language".
    The selected language is 'English'.  As is the Win7 OS installation.
    In order to get the machine back in service, I installed the rest of the software without issues.  The end user does need Civil 3D though.
    Is this due to a license issue - that the old license (from the failed hard drive) is holding up the new installation?
    Please use plain text.
    camilo.lemos
    Re: Civil 3D 2012 Install error - not available for select language
    01-08-2013 01:45 AM in reply to: thanzlik
    Hi thanzlik,
    This thread is for a different product and release but it may be helpful for you.
    Let us know if this helps solve the issue please:smileyhappy:
    Camilo Lemos
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    01-08-2013 06:01 AM in reply to: camilo.lemos
    The link you had lead to this message : "An invalid set of parameters has been specified in the url."
    Member
    01-08-2013 06:09 AM in reply to: thanzlik
    I found the page you were trying to reference :
    http://forums.autodesk.com/t5/Installation-Licensing/language-error-when-trying-to-install-AutoCAD-L...
    Since it was a fresh OS, there was no software installed, so the Design Review issue isn't the issue.
    Neither is the virtual machine an issue.
    I will check the MS Visual C++ 2005 or 2008 Redistributables though.
    Member
    01-08-2013 01:13 PM in reply to: thanzlik
    2005, 2005 x64, 2008, 2008 x64, and 2010 Redistributables are all installed.
    Member
    01-10-2013 06:38 AM in reply to: camilo.lemos
    Any other help on this?
