That's an interesting one to note.
Rodney McManamy
President
CADzation
rmcmanamy@cadzation.com
518 South Route 31 Suite 200
McHenry, IL 60050
www.cadzation.com
Providing Industrial Strength
PDF & DWF Solutions to the
Global CAD Marketplace.
"Mark Douglas" wrote in message
news:40be1f86$2_3@newsprd01...
> Thanks John!! That will probably do the trick.....
> Mark
> "John Schmier (Autodesk)" wrote in
> message news:40be021a_3@newsprd01...
> > Mark, there's a known defect with Composer (and DWF Viewer) and the
print
> > dialog box. If the user adds additional sheets to use during printing,
> they
> > must first either print a test sheet or (to save paper and ink) select
> View
> > Tiles. Then the next time they come back to the print dialog box the
> newly
> > added sheets will be displayed. This has to be done each time Composer
is
> > used. To work around this, have the user set his plotter up with these
> > additional sheets in the system's printer settings.
> > news:40bdeec3$1_3@newsprd01...
> > > I figured out the problem. He was trying to add a Architectural size
> > sheet.
> > > So he had to set all his properties up. Print a test page. Keep
composer
> > > open and issue the Print again. Then his sheets appeared in the dialog
> > box?
> > > Anyone else get this?
> > > Mark
> > > "Rodney McManamy - CADzation" wrote in
message
> > > news:40bcfae3$1_3@newsprd01...
> > > > In Composer if you choose to set a scale factor instead of Best Fit
> > there
> > > is
> > > > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing"
> > > instead.
> > > > Rodney McManamy
> > > > President
> > > > CADzation
> > > > McHenry, IL 60050
> > > > www.cadzation.com
> > > > news:40bcb700$1_2@newsprd01...
> > > > > I was wondering if anyone is having problems with Plotting. A
client
> > we
> > > > have
> > > > > keeps saying that Composer wont let him plot out his sheet in the
> > > correct
> > > > > orientation. It keeps plotting the drawing in tile mode. Anyone
got
> > any
> > > > > ideas? Here is his plotter information.
> > > > > HP Design Jet 430 plotter
> > > > > Any help would be awesome!!!
> > > > > Mark
