Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Plotting Configuaterion
6 REPLIES 6
250 Views, 6 Replies
I was wondering if anyone is having problems with Plotting. A client we have keeps saying that Composer wont let him plot out his sheet in the correct orientation. It keeps plotting the drawing in tile mode. Anyone got any ideas? Here is his plotter information. HP Design Jet 430 plotter Any help would be awesome!!! Mark
6 REPLIES 6
In Composer if you choose to set a scale factor instead of Best Fit there is 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" instead. -- Rodney McManamy President CADzation ------------------------- rmcmanamy@cadzation.com ------------------------- 518 South Route 31 Suite 200 McHenry, IL 60050 www.cadzation.com Providing Industrial Strength PDF & DWF Solutions to the Global CAD Marketplace. "Mark Douglas" wrote in message news:40bcb700$1_2@newsprd01... > I was wondering if anyone is having problems with Plotting. A client we have > keeps saying that Composer wont let him plot out his sheet in the correct > orientation. It keeps plotting the drawing in tile mode. Anyone got any > ideas? Here is his plotter information. > HP Design Jet 430 plotter > > Any help would be awesome!!! > > Mark > >
I figured out the problem. He was trying to add a Architectural size sheet. So he had to set all his properties up. Print a test page. Keep composer open and issue the Print again. Then his sheets appeared in the dialog box? Anyone else get this? Mark "Rodney McManamy - CADzation" wrote in message news:40bcfae3$1_3@newsprd01... > In Composer if you choose to set a scale factor instead of Best Fit there is > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" instead. > > -- > Rodney McManamy > President > CADzation > ------------------------- > rmcmanamy@cadzation.com > ------------------------- > 518 South Route 31 Suite 200 > McHenry, IL 60050 > www.cadzation.com > Providing Industrial Strength > PDF & DWF Solutions to the > Global CAD Marketplace. > > "Mark Douglas" wrote in message > news:40bcb700$1_2@newsprd01... > > I was wondering if anyone is having problems with Plotting. A client we > have > > keeps saying that Composer wont let him plot out his sheet in the correct > > orientation. It keeps plotting the drawing in tile mode. Anyone got any > > ideas? Here is his plotter information. > > HP Design Jet 430 plotter > > > > Any help would be awesome!!! > > > > Mark > > > > > >
Mark, there's a known defect with Composer (and DWF Viewer) and the print dialog box. If the user adds additional sheets to use during printing, they must first either print a test sheet or (to save paper and ink) select View Tiles. Then the next time they come back to the print dialog box the newly added sheets will be displayed. This has to be done each time Composer is used. To work around this, have the user set his plotter up with these additional sheets in the system's printer settings. "Mark Douglas" wrote in message news:40bdeec3$1_3@newsprd01... > I figured out the problem. He was trying to add a Architectural size sheet. > So he had to set all his properties up. Print a test page. Keep composer > open and issue the Print again. Then his sheets appeared in the dialog box? > Anyone else get this? > > Mark > > "Rodney McManamy - CADzation" wrote in message > news:40bcfae3$1_3@newsprd01... > > In Composer if you choose to set a scale factor instead of Best Fit there > is > > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" > instead. > > > > -- > > Rodney McManamy > > President > > CADzation > > ------------------------- > > rmcmanamy@cadzation.com > > ------------------------- > > 518 South Route 31 Suite 200 > > McHenry, IL 60050 > > www.cadzation.com > > Providing Industrial Strength > > PDF & DWF Solutions to the > > Global CAD Marketplace. > > > > "Mark Douglas" wrote in message > > news:40bcb700$1_2@newsprd01... > > > I was wondering if anyone is having problems with Plotting. A client we > > have > > > keeps saying that Composer wont let him plot out his sheet in the > correct > > > orientation. It keeps plotting the drawing in tile mode. Anyone got any > > > ideas? Here is his plotter information. > > > HP Design Jet 430 plotter > > > > > > Any help would be awesome!!! > > > > > > Mark > > > > > > > > > > > >
Thanks John!! That will probably do the trick..... Mark "John Schmier (Autodesk)" wrote in message news:40be021a_3@newsprd01... > Mark, there's a known defect with Composer (and DWF Viewer) and the print > dialog box. If the user adds additional sheets to use during printing, they > must first either print a test sheet or (to save paper and ink) select View > Tiles. Then the next time they come back to the print dialog box the newly > added sheets will be displayed. This has to be done each time Composer is > used. To work around this, have the user set his plotter up with these > additional sheets in the system's printer settings. > > "Mark Douglas" wrote in message > news:40bdeec3$1_3@newsprd01... > > I figured out the problem. He was trying to add a Architectural size > sheet. > > So he had to set all his properties up. Print a test page. Keep composer > > open and issue the Print again. Then his sheets appeared in the dialog > box? > > Anyone else get this? > > > > Mark > > > > "Rodney McManamy - CADzation" wrote in message > > news:40bcfae3$1_3@newsprd01... > > > In Composer if you choose to set a scale factor instead of Best Fit > there > > is > > > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" > > instead. > > > > > > -- > > > Rodney McManamy > > > President > > > CADzation > > > ------------------------- > > > rmcmanamy@cadzation.com > > > ------------------------- > > > 518 South Route 31 Suite 200 > > > McHenry, IL 60050 > > > www.cadzation.com > > > Providing Industrial Strength > > > PDF & DWF Solutions to the > > > Global CAD Marketplace. > > > > > > "Mark Douglas" wrote in message > > > news:40bcb700$1_2@newsprd01... > > > > I was wondering if anyone is having problems with Plotting. A client > we > > > have > > > > keeps saying that Composer wont let him plot out his sheet in the > > correct > > > > orientation. It keeps plotting the drawing in tile mode. Anyone got > any > > > > ideas? Here is his plotter information. > > > > HP Design Jet 430 plotter > > > > > > > > Any help would be awesome!!! > > > > > > > > Mark > > > > > > > > > > > > > > > > > > > >
That's an interesting one to note. -- Rodney McManamy President CADzation ------------------------- rmcmanamy@cadzation.com ------------------------- 518 South Route 31 Suite 200 McHenry, IL 60050 www.cadzation.com Providing Industrial Strength PDF & DWF Solutions to the Global CAD Marketplace. "Mark Douglas" wrote in message news:40be1f86$2_3@newsprd01... > Thanks John!! That will probably do the trick..... > > Mark > > "John Schmier (Autodesk)" wrote in > message news:40be021a_3@newsprd01... > > Mark, there's a known defect with Composer (and DWF Viewer) and the print > > dialog box. If the user adds additional sheets to use during printing, > they > > must first either print a test sheet or (to save paper and ink) select > View > > Tiles. Then the next time they come back to the print dialog box the > newly > > added sheets will be displayed. This has to be done each time Composer is > > used. To work around this, have the user set his plotter up with these > > additional sheets in the system's printer settings. > > > > "Mark Douglas" wrote in message > > news:40bdeec3$1_3@newsprd01... > > > I figured out the problem. He was trying to add a Architectural size > > sheet. > > > So he had to set all his properties up. Print a test page. Keep composer > > > open and issue the Print again. Then his sheets appeared in the dialog > > box? > > > Anyone else get this? > > > > > > Mark > > > > > > "Rodney McManamy - CADzation" wrote in message > > > news:40bcfae3$1_3@newsprd01... > > > > In Composer if you choose to set a scale factor instead of Best Fit > > there > > > is > > > > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" > > > instead. > > > > > > > > -- > > > > Rodney McManamy > > > > President > > > > CADzation > > > > ------------------------- > > > > rmcmanamy@cadzation.com > > > > ------------------------- > > > > 518 South Route 31 Suite 200 > > > > McHenry, IL 60050 > > > > www.cadzation.com > > > > Providing Industrial Strength > > > > PDF & DWF Solutions to the > > > > Global CAD Marketplace. > > > > > > > > "Mark Douglas" wrote in message > > > > news:40bcb700$1_2@newsprd01... > > > > > I was wondering if anyone is having problems with Plotting. A client > > we > > > > have > > > > > keeps saying that Composer wont let him plot out his sheet in the > > > correct > > > > > orientation. It keeps plotting the drawing in tile mode. Anyone got > > any > > > > > ideas? Here is his plotter information. > > > > > HP Design Jet 430 plotter > > > > > > > > > > Any help would be awesome!!! > > > > > > > > > > Mark > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
While were on the Plot Configuration Subject. There has got to be a Preview Button......I've wasted soo much paper trying to get things to plot out correctly..Its too difficult.... Mark "Rodney McManamy - CADzation" wrote in message news:40be616a$1_1@newsprd01... > That's an interesting one to note. > > -- > Rodney McManamy > President > CADzation > ------------------------- > rmcmanamy@cadzation.com > ------------------------- > 518 South Route 31 Suite 200 > McHenry, IL 60050 > www.cadzation.com > Providing Industrial Strength > PDF & DWF Solutions to the > Global CAD Marketplace. > > "Mark Douglas" wrote in message > news:40be1f86$2_3@newsprd01... > > Thanks John!! That will probably do the trick..... > > > > Mark > > > > "John Schmier (Autodesk)" wrote in > > message news:40be021a_3@newsprd01... > > > Mark, there's a known defect with Composer (and DWF Viewer) and the > print > > > dialog box. If the user adds additional sheets to use during printing, > > they > > > must first either print a test sheet or (to save paper and ink) select > > View > > > Tiles. Then the next time they come back to the print dialog box the > > newly > > > added sheets will be displayed. This has to be done each time Composer > is > > > used. To work around this, have the user set his plotter up with these > > > additional sheets in the system's printer settings. > > > > > > "Mark Douglas" wrote in message > > > news:40bdeec3$1_3@newsprd01... > > > > I figured out the problem. He was trying to add a Architectural size > > > sheet. > > > > So he had to set all his properties up. Print a test page. Keep > composer > > > > open and issue the Print again. Then his sheets appeared in the dialog > > > box? > > > > Anyone else get this? > > > > > > > > Mark > > > > > > > > "Rodney McManamy - CADzation" wrote in > message > > > > news:40bcfae3$1_3@newsprd01... > > > > > In Composer if you choose to set a scale factor instead of Best Fit > > > there > > > > is > > > > > 2 options "Tile Drwing" or "Clip Drawing". Try the "Clip Drawing" > > > > instead. > > > > > > > > > > -- > > > > > Rodney McManamy > > > > > President > > > > > CADzation > > > > > ------------------------- > > > > > rmcmanamy@cadzation.com > > > > > ------------------------- > > > > > 518 South Route 31 Suite 200 > > > > > McHenry, IL 60050 > > > > > www.cadzation.com > > > > > Providing Industrial Strength > > > > > PDF & DWF Solutions to the > > > > > Global CAD Marketplace. > > > > > > > > > > "Mark Douglas" wrote in message > > > > > news:40bcb700$1_2@newsprd01... > > > > > > I was wondering if anyone is having problems with Plotting. A > client > > > we > > > > > have > > > > > > keeps saying that Composer wont let him plot out his sheet in the > > > > correct > > > > > > orientation. It keeps plotting the drawing in tile mode. Anyone > got > > > any > > > > > > ideas? Here is his plotter information. > > > > > > HP Design Jet 430 plotter > > > > > > > > > > > > Any help would be awesome!!! > > > > > > > > > > > > Mark > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
