Realtime Vs RT material
The power in VRED is the ability to view something in realtime/VR then use the same data-set for a raytraced image. It'd be great if there was more control over how materials look between the two.
In the past I've created complex switch/variant layouts or even completely separate files between the two presentation methods... and I'm sure I'm not the only one.
The main issues revolve around transparency (including SSS) and displacement.
For example: Subsurface scattering makes a plastic material look odd in the realtime viewer - it'd be good if we had the option to toggle it off for the real-time view (or to choose a transparent/glass material to represent it instead).
An example for displacement would be that I don't want displacement shown at all in real-time (or a custom replacement Bump map is shown instead) due to the performance hit. I'd only like displacement active when I hit the Raytracing button.
Thanks.
1 Comment
richardlevene
Hi @Anonymous
That sounds like things you probably could script as they are sort of hacks.
But would it not be nice if vred used a material definition language that would be consistent between its raytracing and openGL renderers? That would also be consistent between CPU and GPU raytracing and one that was also compatible with other applications so you could move things through various apps?
If you are into that upvote these Vred Ideas
https://forums.autodesk.com/t5/vred-ideas/usd-and-gltf-import-export/idi-p/10307445
https://forums.autodesk.com/t5/vred-ideas/nvidia-s-mdl-materials-in-vred/idi-p/9853658
Best,
Richard
