Better VRED Phyton Documentation with code examles
i work on VRED 2016 for a major car company in wolfsburg.
i'm trying to generate Materials from a XML based Material library. I encounter some issues with creating Materials via Python Script.
for example:
fieldAccess parameters for imageMaps are not consistent. u always have to experiment ---> roughnessMap works different than specularMap
i could create a specularMap but no roughnessMap
Why create a specularMap for a UPlasticMaterial, wich uses glossyMaps in the Material Editor
How to access the Use ICC Profile field and set Input Gamma via script instead
How to access Lab values for Material Colors via script
Big Problem also while investigating:
The NodeEditor doesn't update on Material Editor changes and vice versa.
The Documentation is only Useful for experienced Programmers
2 Comments
lukas_faeth
Hi Community,
thanks for this Idea. To be able to address this poperly. Can you give us some input on what you would like to improve in regards to the documentation and examples exactly?
thanks in advance,
Lukas
lukas_faeth
Status changed to: Accepted
