VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
XRite Displacement field (Python)
4 REPLIES 4
356 Views, 4 Replies
I have an x-rite scanned material and can't find how to check/uncheck the displacement field using scripts.
The script I usually use (below) doesn't work.
mat = findMaterial("materialName_SVBRDF")
colorComponentData = vrFieldAccess(mat.fields().getFieldContainer('colorComponentData'))
displacementComponent = vrFieldAccess(colorComponentData.getFieldContainer('displacementComponent'))
displacementComponent.setBool("useTexture", false)
I can't see the field container needed in the node editor as the x-rite material seems to function as a switch.
Thanks in advance!
4 REPLIES 4
richardlevene
Hmm i'm not sure the the X-Rite material has a displacement parameter by default so maybe that is probably the issue? I think it is dependent if it is added within the axf/cpa/btf file itself to appear. Car paint axf files scans I have do not show any form of displacement option. But some of the xrite example scans that ship with vred in the asset manager have the displacement option.
in reply to: richardlevene
Yeah maybe, but that doesn't fill me with hope haha.
To my knowledge it depends how the material is defined in Pantora before scanning. The materials I have scanned are defined as textiles so they have the displacement field.
If VRED can read the .axf and decide if it's to display the displacement as a parameter or not - surely this is accessible in some way. Smiley Frustrated
richardlevene
Yeah you are right about Pantora and which material option you pick.
But yes when I drag a xrite material that has displacement onto the Node Editor I do not see any of those parameters. To be honest I can't seem to see any of the actual main parameters for it in the node editor.
Will have to leave this to the devs to answer.
the xrite material is basically a switch material, it does not have any of the normal material fields. You will have to get the real measured material from the "materials" multifield before you can do anything. But you might need to manually force an update on the xrite material as well when changing something.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
