We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Vred2019 Pro - what happen to python execfile ?!
Bob.Bon2000
Message 1 of 8
Bob.Bon2000
What is the new replacement for :
s.send("/python?value=execfile('C://test//x.py)'".encode())
All I get is
Couldn't execute command 'execfile('C://test//...'!
Thanks.
Replies (7)
Message 2 of 8
marcus_fritzen
in 2019 we made some changes regarding the security of some Python calls. However, you can revert it by starting VRED with the command line option "-insecure_python". Hope that helps.
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
Message 3 of 8
Bob.Bon2000
Hmm I had a feeling this is going to happen.
Will this functionality remain or it will be removed within next 10 releases?
Message 4 of 8
seiferp
There will never be a solution that fits for all. But if an IT department of a company with hundreds of licenses sees this as a security issue and showstopper to roll out ... we do these adjustments. Sorry if it broke something else.
Message 5 of 8
Bob.Bon2000
Hey
yeah I agree, it was quite a security issue, but at the same time in closed networks, it did not matter and allowed us  to build up quite a few systems on it.
In this case, how can we tell vred to execute a script after he finish his startup procedure?
TIA
Message 6 of 8
marcus_fritzen
as I wrote, your code will work like in previous versions if you start VREDPro with the command line option
"-insecure_python". You can add it e.g. to the desktop shortcut by right-click on the shortcut -> Properties, there you need to add it to the "Target" which should end up in something like this: "C:\Program Files\Autodesk\VREDPro-11.0\bin\WIN64\VREDPro.exe" -insecure_python.
Another solution would be to use another command line option called "-postpython", which will execute after VRED has launched or loaded a scene (see command line option description: VREDPro.exe --help).
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
Message 7 of 8
Bob.Bon2000
Humh... bit tricky. Is there no folder in vred like plugins/autostart or something like that where we could place .py files and let vred auto execute them on start?
Message 8 of 8
marcus_fritzen
No, there is no autostart folder.
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
