VRED Pro 2020 or 2021 VR Menu Python script toggle
Shawn_Collins-Lopez
Shawn_Collins-Lopez
Hi Pascal, I was looking for a Python script to toggle the VR menu on and off using a Variant and not just on the Vive controller when in OpenVR HMD mode.  I found the following in the documentation but I am not able to get it to work.
vrdImmersiveMenu.setVisible(True)
Found the script here: file:///C:/Program%20Files/Autodesk/VREDPro-13.0/doc/v2/class_vrdImmersiveMenu.html?highlight=vr%20m...
This is the error in the terminal:
Traceback (most recent call last):
File "<string>", line 1, in <module>
TypeError: descriptor 'setVisible' requires a 'vrKernelServices.vrdImmersiveMenu' object but received a 'bool'
My Python skills are not able to fix it. I did try this script:
vrKernelServices.vrdImmersiveMenu.setVisible(True)
No luck
In addition I was really looking to add a timer to the VR Menu to auto close because of the users issues having it left open.  If anyone knows of a Python script for this please share!
Thank you,
Shawn
Shawn_Collins-Lopez
Hey Pascal, I found the correct Python command:
vrImmersiveUiService.showToolsMenu(True)
This works!  Now I need to make a timer for the VR Menu
Thank you,
Shawn
seiferp
Good 👍
