VRED play-pause animation with a key
hobbotuk
Message 1 of 25
hobbotuk
Hi!
I would like to play/pause an animation clip (if it not possible, play/pause the timeline with a key its ok too)
I have try it  using Python (Vsets let me play animations clips, but I dont know how to plause from them) but in Python I need to know if the animation is playing (to make an "if" to play it or to pause the animation), and I dont know how to use isPlaying() command
So, any kind of solution (by python or any other way) its ok for me!
some ideas?
Thanks!
Replies (24)
Message 2 of 25
ir
This works for me:
def hvpDrive():
 playCAnimation("drive",0,340)
def hvpPause():
 pauseCAnimation("drive",True)
 vrLogWarning("Paused drive animation...")
def hvpCont():
 pauseCAnimation("drive",False)
 vrLogWarning("Executing drive animation...")
keyP = vrKey(Key_P)
keyP.connect(hvpPause)
keyC = vrKey(Key_C)
keyC.connect(hvpCont)
Message 3 of 25
after i press pause and want to continue the animation, it jumps back to the beginning of the animation and restarts from there.
Is ther a way to continue the animation from where it stoped at pushing pause ?
Thank you,
Andreas
Message 4 of 25
marcus_fritzen
actually it should resume from where it was paused.
/Marcus
Marcus Fritzen
Principal Engineer
Message 5 of 25
Is possible to use only one key to Play/Pause the animation?
Because I can't find nothing about the script code for this
Message 6 of 25
marcus_fritzen
Sure, use only one function and remember the state with a boolean.
Marcus Fritzen
Principal Engineer
Message 7 of 25
Thanks for your reply!
I am new in this, so I don't understand so much.....
Please can you write the code???
If I want to play the animation should I write playCAnimation("name")
but if I want to pause/unpause the animation with only a key should I write isPlaying() ???
But what should I put into the parenthesis?
Message 8 of 25
marcus_fritzen
Here is some untested Python code. Maybe it helps. Keep in mind that it doesn't check if the animation has finished playing.
isPlaying = False
isPausing = False
def myPlayToggle():
    global isPlaying
    global isPausing
    if not isPlaying:
        playCAnimation("Test")
        isPlaying = True
    else
        isPausing =  not isPausing
        pauseCAnimation("Test", isPausing)
Marcus Fritzen
Principal Engineer
Message 9 of 25
If I want to "click" instead to use a key to play or pause the animation......what could be the script for this?
For example, for the key is this : keyP = vrKey(Key_P)
But, for a "click" with the mouse, what can I do?
Message 10 of 25
Christian_Garimberti
Create a variant set with the function myPlayToggle() in the script section.
Create a touchsensor on the geometry you want to use as "button"
Associate the script to the touchsensor.
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 11 of 25
thanks for your reply!
I was trying to use this script, but doesn't work........
isPlaying = False
isPausing = False
def myPlayToggle():
    global isPlaying
    global isPausing
    if not isPlaying:
        isPlaying = True
    else
 maybe something is missing....
Message 12 of 25
hi, in the script there is a an error...
after the else you have to put  :
isPlaying = False
isPausing = False
def myPlayToggle():
    global isPlaying
    global isPausing
    if not isPlaying:
        playCAnimation("My Clip")
        isPlaying = True
    else:
        pauseCAnimation("My Clip", isPausing)
and, obviously, where you see "test" or "My Clip", you have to put the name of your clip
Chris
Message 13 of 25
Good morning,
Yes, I know that I have to put te name of my clip, and thanks for the else:
but still doesn't work......
If I want to use only this script doesn't work, but, for example, if I put at the end :
keyP = vrKey(Key_P)
keyP.connect(myPlayToggle)
obviously works....but instead to use a key, I want to click with the mouse or use the Touch Sensor, so, what can I write here??????
Thanks!
Message 14 of 25
write the myPlayToggle() in the script section of a variantset
then connect the variantset with a touchsensor
this should works
Chris
Message 15 of 25
marcus_fritzen
the script was only a hint how things could work and yes, there was a ":" missing behind "else".
Besides that, c.garimberti already wrote what you need to do. Create a VariantSet, put the myPlayToggle call into the script tab, create a touch sensor and attach the newly created VariantSet to it.
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
Message 16 of 25
seiferp
Attached a demo file
Message 17 of 25
Thanks to all of you!!!!!!
It works!
Message 18 of 25
I tried to copy what you did here, but my plane stops spinning after a single revolution. I tried to change it post infinity mode to loop, but that doesn't work.
Rob
Message 19 of 25
To run a clip on a infinite loop you have to put -1 on the cycle box in the clip panel.
Note: you can use the -1 only in recent release of Vred, but i don't remember in which version this feature it has been added.
Chris
Message 20 of 25
Thank you!
Could you also tell me how to reverse the rotation in a second switch?
Regards
Rob
