VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
VRED Go
2 REPLIES 2
370 Views, 2 Replies
VRED Go
I did small animation by moving two parts and export that file as VRED GO file just to check file size, but file size is 300 mb .  I again I checked with by Importing a car and did door animation , here file size was 2 GB . Is there any way to compress it ? or any alternate option ? to keep it in minimum size.  In this condition it is difficult to share and open exe file by other person in their normal system.
2 REPLIES 2
Christian_Garimberti
Hi, you have to play around your model to keep it the lighter possible.
Try to see if importing it with a less tessellation setting keep the geometry lighter, or check if you can share some part of it.
Or simply remove some part if not needed...
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
in reply to: Christian_Garimberti
 Thanks for your response. Sure I will try and see.
