VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Vred Design - Water caustics
2 REPLIES 2
Pete-S
1009 Views, 2 Replies
Hey guys,
I'm trying to produce some renders of a motor yacht but i'm missing the water caustics that would help finish off the image. In fact I'm having to use a chrome shader with stretched bump structure to simulate the water itself.
Is there anyway I can get water caustics to reflect on the above water section of the hull?
2 REPLIES 2
florian.dyck
in reply to: Pete-S
Hi Peter
I just tried and somehow VRED Design doesn't calculate GI with caustics. I used Professional and it worked, but not with Design. I attached to scene file for you to test. If you like, send me your hull and water surface and I can render for you 😉
Pete-S
in reply to: florian.dyck
Hi Florian,
Thanks for the reply. I've just tried your test file and I'm also not getting caustics in Vred Design, perhaps it's not something that design is equiped with... 😞 I'll keep looking. Unfortunately I can't give you the hull design for you to have a go in pro with at present as it has not reached a stage where it can be shared publicly.
