VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
VRED Collision for VR (HTC Vive)
8 REPLIES 8
Message 1 of 9
2496 Views, 8 Replies
Hi there
Another question about Virtual Reality!
I'm wanting to program in some Collision to activate, say, a colour switch when you touch a cube with your controller.
So far I've parented a sphere to my motion controller and tried using the python code to reference that and the VSets I have set up to activate the switch.
So, my sphere is the 'PickerL'
The 'Blue_Box' etc are my geometry
and the 'Blue' etc are the VSets.
## Collision Activation
Picker = findNode("PickerL")
Blue_Box = findNode("Blue_Box")
Green_Box = findNode("Green_Box")
Red_Box = findNode("Red_Box")
def Boxes():
	global CollisionBlue_Box
	global CollisionGreen_Box
	global CollisionRed_Box
	CollisionBlue_Box = vrCollision([Picker], [Blue_Box])
	CollisionBlue_Box.connect(Blue_Switch)
	CollisionGreen_Box = vrCollision([Picker], [Green_Box])
	CollisionGreen_Box.connect(Green_Switch)
	CollisionRed_Box = vrCollision([Picker], [Red_Box])
	CollisionRed_Box.connect(Red_Switch)
def Blue_Switch():
    selectVariantSet("Blue")
def Green_Switch():
    selectVariantSet("Green")
def Red_Switch():
    selectVariantSet("Red")
Boxes()
Attached is a screen grab of my project!
Any help on this would be great!
8 REPLIES 8
Message 2 of 9
I solved it in the end! So much simpler than I thought!
PickerR = findNode ("PickerR")
PickerL =findNode ("PickerL")
Red_Box = findNode ("Red_Box")
coll = vrCollision([PickerR, PickerL], [Red_Box])
coll.connect(Red_Switch)
controller1.triggerHapticPulse(0,1000)
def Red_Switch():
Message 3 of 9
Your code was  useful . I just tried with your method but its showing  not defined (error).
Message 4 of 9
Hello!
Yes, I had this same issue and it still occurs, the way I worked around it was by typing in quotation marks in the following section like so:
coll.connect(“Red_Switch”)
I then run the script and take out the quotation marks and run it again - and it works, there’s obviously something I’ve missed but that’s got it working for me.
Also, the triggerHapticPulse command should go under where you define the switch instead!
def Red-Switch():
I hope this helps
Harry
Message 5 of 9
#PickerR = findNode("PickerR")
PickerL = findNode("PickerL")
plane = findNode("Planegreen")
plane = findNode("Planeblue")
def Boxes():
global CollisionPlanegreen
global CollisionPlaneblue
CollisionPlanegreen = vrCollision([PickerL],[Planegreen])
CollisionPlanegreen.connect(box_blue)
CollisionPlaneblue = vrCollision([PickerL],[Planeblue])
CollisionPlaneblue.connect(box_green)
controller0.triggerHapticPulse(0,1000)
def box_blue():
selectVaraintSet("box_blue")
def box_green():
selectVaraintSet("box_green")
def trigger0Pressed():
controller0.setPickingAxis(0)
controller0.showPickingAxis(true)
def trigger0Released():
pickedNode = controller0.pickNode()
selectNode(pickedNode)
controller0.showPickingAxis(false)
def controller0Moved():
if controller0.isTouchpadPressed():
leftNode = findNode("MatrixLeft")
leftNode.setTransformMatrix( controller0.getWorldMatrix(), false)
#controller main function
controller0 = vrOpenVRController("Controller0")
controller0.connectSignal("controllerMoved", controller0Moved)
controller0.connectSignal("triggerPressed", trigger0Pressed)
controller0.connectSignal("triggerReleased", trigger0Released)
#controller0.connectSignal("touchpadPressed", touchpad0Pressed)
#controller0.connectSignal("touchpadReleased", touchpad0Released
#controller0.connectSignal("gripPressed", grip0Pressed)
#controller1 = vrOpenVRController("Controller1")
#controller1.connectSignal("controllerMoved", controller1Moved)
#controller1.connectSignal("triggerPressed", trigger1Pressed)
#controller1.connectSignal("triggerReleased", trigger1Released)
#controller1.connectSignal("touchpadPressed", touchpad1Pressed)
#controller1.connectSignal("touchpadReleased", touchpad1Released
#controller1.connectSignal("gripPressed", grip1Pressed)
This was my code . But I got error controller 1 not defined and I dont know
where to correct myself.
Message 6 of 9
Hello
Looking at your code, you should remove the hashtag '#' at the start of your controller0 and controller1 signals, as well as your PickerR Variable.
Python doesn't read anything after a hashtag '#' as useable code, anything after that are deemed comments for reference purposes only.
Try removing those, and see if that works! (See example below)
Harry
Message 7 of 9
  I couldnt understand the meaning of these lines .
moveScaleSideways = -2.0 * touchPos.x() *touchPos.x() *touchPos.x()
moveScaleForward = -0.05 * touchPos.y() * touchPos.y() * touchPos.y() *touchPos.y()*touchPos.y()
clipPos = Pnt3f( cMatrix[3], cMatrix[7], cMatrix[11])
clipNor = Vec3f( cMatrix[2], cMatrix[6], cMatrix[10])
I have attached file , where I took these lines from those script .
Message 8 of 9
lbs_markus_s
Hi
the script is always executed from top to bottom
so you first have to define Red_Switch
def Red_Switch():
and use the name afterwards in the script
right now it executes the variant set as long it detects a collision. So if you have a Color Switch material which is Looping it is changing the colors very fast and you cant really see it. It's just flickering . Is there a way of Scripting a time Frame for the collision duration until it switches to the next Color
regards
Markus
Message 9 of 9
in reply to: lbs_markus_s
Is possible to deactivate the Collision with the controllers????
I only want to change the object when I press the trigger, but when I am close, the object change.
