VRED 2025 "Failed to initialize graphics backend for OpenGL."-issue
Hi there,
I didn't saw any useful thread post on this issue so I created one for my case.
The error message is "Failed to initialize graphics backend for OpenGL." and I can only Accept it with "OK".
Otherwise is behind the Onboarding window VRED open with also a white area inside the UI.
I guess there should be something displayed.
This is my PC:
Processor 12th Gen Intel(R) Core(TM) i5-1235U 1.30 GHz
Installed RAM 16,0 GB
And The current Driver version is 31.0.101.5522
I need help to fix this issue.
The complete LOG is here:
Log file from 13.06.2024 12:35:34
2024-06-13 12:35:34 vred kernel version 17.0 x64 (2024-03-20)
2024-06-13 12:35:34 OpenGL version 4.600000 GLSL version 460
2024-06-13 12:35:34 OpenGL vendor Intel
2024-06-13 12:35:34 OpenGL renderer Intel(R) UHD Graphics
2024-06-13 12:35:35 Initializing OpenSG ...
2024-06-13 12:35:35 Loaded 'vrAssets' library.
2024-06-13 12:35:35 Loaded 'vrImmersiveInteraction' library.
2024-06-13 12:35:35 Loaded 'vrADPKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrBakeKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrCameraKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrClusterKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrDecoreKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrGUIKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrLightKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrMaterialKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrMessagePipeKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrMetadataKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrPLMXMLKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrQueryKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrReferenceKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrScenegraphKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrSessionKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrUVKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrUVTextureProjectionKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrVolumeKernelModule' library.
2024-06-13 12:35:35 Loaded 'vrWebEngineModule' library.
2024-06-13 12:35:35 Loaded 'vrKernelServicesImpl' library.
2024-06-13 12:35:35 vrPlatform::getDataDir(): C:\ProgramData\Autodesk\VREDPro-17.0\data
2024-06-13 12:35:35 SynColor UserPath: C:\ProgramData\Autodesk\VREDPro-17.0\data\SynColor\user_transforms
2024-06-13 12:35:35 Using Substance Render Engine 'OpenGL 3.x'.
2024-06-13 12:35:35 HDR mode is not supported.
2024-06-13 12:35:35 Intel CPU detected
2024-06-13 12:35:35 CPU supports SSE4.2
2024-06-13 12:35:35 CPU supports AVX2
2024-06-13 12:35:35 AVX2 Support available
2024-06-13 12:35:35 Trying to load library C:\Program Files\Autodesk\VREDPro-17.0\bin\WIN64\vrRaytracingUtilsAVX.dll
2024-06-13 12:35:35 Using raytracing library vrRaytracingUtilsAVX, Rendermode rgb
2024-06-13 12:35:35 Loaded 'Module\vrPreferencesModule' plugin.
2024-06-13 12:35:35 Loading Plugins ...
2024-06-13 12:35:35 Loaded plugin 'vrKernelPreferences.dll'
2024-06-13 12:35:39 Loaded plugin 'vrFade.dll'
2024-06-13 12:35:39 Loaded plugin 'vrFrame.dll'
2024-06-13 12:35:39 Loaded plugin 'vrInterpolator.dll'
2024-06-13 12:35:39 Loaded plugin 'vrMenu.dll'
2024-06-13 12:35:39 Loaded plugin 'vrMoviePlayer2.dll'
2024-06-13 12:35:39 Loaded plugin 'vrSwitch.dll'
2024-06-13 12:35:39 Loaded plugin 'vrVideoGrab.dll'
2024-06-13 12:35:39 Loaded plugin 'vrVirtualEye.dll'
2024-06-13 12:35:39 Loaded plugin 'vrWebOverlay.dll'
2024-06-13 12:35:39 Loaded plugin 'vrWidget.dll'
2024-06-13 12:35:39 Loaded plugin 'vrCollision.dll'
2024-06-13 12:35:39 Loaded plugin 'vrJoystick.dll'
2024-06-13 12:35:39 Loaded plugin 'vrKey.dll'
2024-06-13 12:35:39 Loaded plugin 'vrSpacemouse.dll'
2024-06-13 12:35:39 Loaded plugin 'vrSpeech.dll'
2024-06-13 12:35:39 Loaded plugin 'vrTimer.dll'
2024-06-13 12:35:39 Loaded plugin 'vrTouchSensorEvent.dll'
2024-06-13 12:35:39 Loaded plugin 'vrViewPoint.dll'
2024-06-13 12:35:39 Loaded plugin 'vr3DS.dll'
2024-06-13 12:35:39 Loaded plugin 'vrATF.dll'
2024-06-13 12:35:39 Loaded plugin 'vrC4d.dll'
2024-06-13 12:35:39 Loaded plugin 'vrDWFLoader.dll'
2024-06-13 12:35:39 Loaded plugin 'vrSLPLoader.dll'
2024-06-13 12:35:39 Loaded plugin 'vrWRL.dll'
2024-06-13 12:35:39 Loaded plugin 'vrAnimationModule.dll'
2024-06-13 12:35:39 Loaded plugin 'vrAnimationWidgets.dll'
2024-06-13 12:35:39 Loaded plugin 'vrAnnotationModule.dll'
2024-06-13 12:35:39 Loaded plugin 'vrAssetsModule.dll'
2024-06-13 12:35:39 Loaded plugin 'vrBakeLightModule.dll'
2024-06-13 12:35:39 Loaded plugin 'vrCAD.dll'
2024-06-13 12:35:39 Loaded plugin 'vrCameraEditor.dll'
2024-06-13 12:35:39 Loaded plugin 'vrClippingModule.dll'
2024-06-13 12:35:39 Loaded plugin 'vrCubeImages.dll'
2024-06-13 12:35:39 Loaded plugin 'vrFinalRenderPass.dll'
2024-06-13 12:35:40 Loaded plugin 'vrGeometryEditor.dll'
2024-06-13 12:35:40 Loaded plugin 'vrGeoPainter.dll'
2024-06-13 12:35:40 Loaded plugin 'vrGridHelper.dll'
2024-06-13 12:35:40 Loaded plugin 'vrHPC.dll'
2024-06-13 12:35:40 Loaded plugin 'vrHPCNodePool.dll'
2024-06-13 12:35:40 Loaded plugin 'vrInteractionModule.dll'
2024-06-13 12:35:40 Loaded plugin 'vrLightEditor.dll'
2024-06-13 12:35:40 Loaded plugin 'vrMaterialEditor.dll'
2024-06-13 12:35:40 Load time: 0.067900
2024-06-13 12:35:40 Loaded plugin 'vrMeasurementModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrMediaEditor.dll'
2024-06-13 12:35:41 Loaded plugin 'vrMetadataEditor.dll'
2024-06-13 12:35:41 Loaded plugin 'vrNodeEditor.dll'
2024-06-13 12:35:41 Loaded plugin 'vrNotificationModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrOpenPDMPlugin.dll'
2024-06-13 12:35:41 Loaded plugin 'vrOptimize.dll'
2024-06-13 12:35:41 Loaded plugin 'vrOptimizer.dll'
2024-06-13 12:35:41 Loaded plugin 'vrPLMXMLModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrPostprocessing.dll'
2024-06-13 12:35:41 Loaded plugin 'vrPreferencesModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrReferenceEditor.dll'
2024-06-13 12:35:41 Loaded plugin 'vrRenderLayerModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrRenderQueueModule.dll'
2024-06-13 12:35:41 Loaded plugin 'vrRenderSettings.dll'
2024-06-13 12:35:41 Creating default studio environment.
2024-06-13 12:35:41 Initializing Studio as default studio environment material.
2024-06-13 12:35:41 Initializing Environments as default environment material.
2024-06-13 12:35:42 Loaded plugin 'vrRulerModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrScenegraphModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrSceneplateEditor.dll'
2024-06-13 12:35:42 Loaded plugin 'vrSelectionModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrSequencerModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrSessionModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrSurfaceAnalysisModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrTouchSensorModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrTransformHelper.dll'
2024-06-13 12:35:42 Loaded plugin 'vrTransformModule.dll'
2024-06-13 12:35:42 Loaded plugin 'vrUVEditor.dll'
2024-06-13 12:35:44 Loaded plugin 'vrVariants2.dll'
2024-06-13 12:35:44 Loaded plugin 'vrVariantSets2.dll'
2024-06-13 12:35:44 Loaded plugin 'vrVredUi.dll'
2024-06-13 12:35:44 Loaded plugin 'vrVRMLViewPoints.dll'
2024-06-13 12:35:44 Loaded plugin 'vrVrpnTrackingModule.dll'
2024-06-13 12:35:44 Loaded plugin 'vrWebShopsModule.dll'
2024-06-13 12:35:44 Detected 1 cpu's with 6 cores and 12 logical cores.
2024-06-13 12:35:44 Loaded 'vrKernelServicesPython' library.
2024-06-13 12:35:44 Python 3.11.7 (tags/v3.11.7:fa7a6f2, Dec 4 2023, 19:24:49) [MSC v.1937 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license" for more information.
2024-06-13 12:35:45 Initializing Vulkan
2024-06-13 12:35:45 OpenGL Device does not support the dlss extensions, disabling DLSS Support
2024-06-13 12:35:45 No DLSS compatible devices found, disabling support
2024-06-13 12:35:45 Device Extension VK_NVX_image_view_handle not found on device
2024-06-13 12:35:45 Device Extension VK_NVX_binary_import not found on device
2024-06-13 12:35:45 OpenGL Device does not support the requested extensions, continuing without the extensions
2024-06-13 12:35:45 Initialized Vulkan Device Intel(R) UHD Graphics
2024-06-13 12:35:45 Initializing Vulkan took 34.046100 milliseconds
2024-06-13 12:35:45 Loaded system monitor profile 'C:\Windows\system32\spool\drivers\color\sRGB Color Space Profile.icm'!
2024-06-13 12:35:45 Loaded image profile 'C:\ProgramData\Autodesk\VREDPro-17.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
2024-06-13 12:35:45 Loaded adobe rgb 98 profile 'C:\ProgramData\Autodesk\VREDPro-17.0\data\MonitorProfiles\AdobeRGB1998.icc'!
2024-06-13 12:35:45 Loaded srgb profile 'C:\ProgramData\Autodesk\VREDPro-17.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
2024-06-13 12:35:45 Loaded simpleGamma profile 'C:\ProgramData\Autodesk\VREDPro-17.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
2024-06-13 12:35:45 Switched to Substance Render Mode 'Automatic' with 'OpenGL 3.x' Engine.
2024-06-13 12:35:45 Initializing Shadow as default shadow material.
2024-06-13 12:35:45 Loaded 'vrKernelServicesImpl' library.
2024-06-13 12:35:45 Looking for script plugins in 'C:\Program Files\Autodesk\VREDPro-17.0\lib\plugins\WIN64\Scripts' ...
2024-06-13 12:35:45 Loaded 'QtQuickStreaming' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/QtQuickStreaming'.
2024-06-13 12:35:45 Loaded 'MRMarkerTrackingModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Loaded 'VRFlashlightModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Loaded 'VRGatherUsersModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Loaded 'VRHideAvatarsModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Loaded 'VRMeasureModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Loaded 'VRMenuSetupModule' Python plugin from 'C:/Program Files/Autodesk/VREDPro-17.0/lib/plugins/WIN64/Scripts/VRMenu'.
2024-06-13 12:35:45 Looking for script plugins in 'C:/Users/<USERNAME>/Documents/Autodesk/VRED-17.0/ScriptPlugins' ...
2024-06-13 12:35:45 Load time: 0.013101
2024-06-13 12:35:46 vrKey Shift+Q is already defined
2024-06-13 12:35:46 vrKey Shift+W is already defined
2024-06-13 12:35:46 vrKey Shift+E is already defined
2024-06-13 12:35:46 vrKey Shift+R is already defined
2024-06-13 12:35:46 FATAL OpenSG Couldn't compile fragment program!
ERROR: 0:2216: '' : syntax error: ERROR___HEXADECIMAL_CONST_OVERFLOW
ERROR: 0:6195: '' : inconsistent qualifiers: storage
2024-06-13 12:35:46 FATAL OpenSG Couldn't link vertex and fragment program!
Out of resource error.
2024-06-13 12:35:47 FATAL OpenSG Couldn't compile fragment program!
ERROR: 0:2377: '' : syntax error: ERROR___HEXADECIMAL_CONST_OVERFLOW
ERROR: 0:2328: '' : syntax error: ERROR___HEXADECIMAL_CONST_OVERFLOW
ERROR: 0:2379: '' : syntax error: ERROR___HEXADECIMAL_CONST_OVERFLOW
2024-06-13 12:35:48 Startup time 14.184 seconds
