VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
vred 2022.3 download
2 REPLIES 2
andrea.cristina
328 Views, 2 Replies
hello all
since we cannot install directly vred from the autodesk app, our ict is downloading the installations for vred 2022.3
(we'd rather go with a mature version)
but it looks like via website the downloaded file is 2022_2.
is there a way to download 2022.3?
2 REPLIES 2
When logging into your account on https://manage.autodesk.com/cep/#products-services/all
you should have all your applications listed. Click on the VRED 2022 version and then in the popup on Updates and Add-Ons. This should list you all download versions available to you.
Just a side note: The dot releases are not minor releases, they are feature releases like any other release.
Michael Nikelsky
Sr. Principal Engineer
thanks.
just a quick issue i've note openening an old 2020 scene in 2022.3
material preview images are not rendering properly.
in open gl mode, if i click update preview image, it copies the same image for each material in the scene (preview is the same for every material).
but if i change environment they look correct.
if i update them again they look screwed with the new environemnt, but ok with the old one.
