VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
VRED 2015: Material Texture Scale
2 REPLIES 2
1412 Views, 2 Replies
Hi, the situation is:
  • Same file
  • Same texture material customized
  • Two different skins from Alias into two different nodes but same top node.
Problem:
Applying same material over the nodes, the texture visualization has two different scales. The normals are OK in both surfaces.(green)
Question:
How can I optimize the skins in order to have the same texture scale visualization?
Image:
Tags (1)
2 REPLIES 2
richardlevene
Somewhere on the groups the scales are different so you need to flush the transforms on the objects. Click on the group and go to edit - optimise module. Then select the flush transforms. There are a few for translate, scale and rotate.
That should do it.
Let us know.
Richard
Thank you very much Ricard.
It works, material textures are unified.
