Video Animation as Texture
Hi guys,
I would like to create a simple plane and make it look like screen (tv/billboard). For example, user can interact with VR, they gonna click (hit) this plane as touch sensor and video will be play or pause, is it possible guys ? If you can help it would be great..
I tried this script down below and working very well, but how can i make it touch sensor for play/stop/pause ability ?
mp = vrMoviePlayer2(findMaterial("PlasticMaterial"), "C:/users/username/desktop/video.avi")
mp.setLoop(true)
mp.setActive(true)
note: diffuse and glossy texture channels are black as known from this topic:
https://forums.autodesk.com/t5/vred-forum/load-animated-texture-files-vred/td-p/5597561
if .mp4 support it would be better because of file size (avi is huge rather than mp4)..
Thank you and Best Regards
Nadja.Bueckmann
Hi @Anonymous,
which version of Vred are you using?
If I understand it right your script is working fine in Vred. So is your question is how to apply it to a touch sensor?
If you like you can attach your setup you already have to that case, then I can have a look.
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Hey, @Nadja.Bueckmann
My Vred version is : Vred Professional 2017.2
I`m trying to send file but .avi file over 80 mb and i cant even send vred file because its connected to .avi file somehow in forum doesn`t allow me to do that !, there is a simle plane and trying to project my animation via script:
mp = vrMoviePlayer2(findMaterial("video"), "D:/VR/video.avi")
mp.setLoop(true)
mp.setActive(true)
Script working fine as i told you, just what i wanna know, video always looping there, i would like to make this plane as a touch sensor and when i click it play/pause could be happen. Do i need edit script for that or what kind of variant set do i need to create for the touch sensor ?
And another problem is when i execute this script in material editor slot, material name automatically changing it own name, for example instead of `video` its becoming `videoqrap` therefore every restart i have to change material name `videoqrap` to `video` again otherwise script can not find the material (video)!
And only .avi file can work with vred, it would be perfect supporting.mp4 file type because of video size is so big i cant even upload here!
Thank you & Best Regards
lbs_markus_s
sinje_thiedemann
Hi @Anonymous,
yes, you need a variant set with this line in Script tab:
mp.setActive(not mp.isActive())
Yes, putting the material in the vrMoviePlayer2 constructor changes the material name to "videograb". You cannot prevent it, but do a workaround: Remember the name before and set it again on the material afterwards:
material = findMaterial("video")
mp = vrMoviePlayer2(material, "D:/VR/video.avi")
material.setName("video")
Best regards
Sinje
Thank you very much all off you and @sinje_thiedemann totally worked as you describe..
Best Regards
hi, thank you for sharing this wonderful post. I appreciate much, iv'e been searching video editor since morning, until such time i saw your post. it was a great indeed to me. Before i'm just using an online video maker which is the LightMV, this one is a friendly editor. you must try it also.
