varjo mr - video pass-through material - hole in MR
d.barboni
d.barboni
Hi to all,
I want to make a hole in in a 3d model to see outside.
I've seen that is possible to do it in unreal or unity using a 3d surface that make the shape of the hole with a pass-through material attached.
there is a video in youtube where the user can see the real keyboard with a marker attached.
how can i do it in vred?
i haven't find anything about this material ( or something to script in python ) to make this hole.
Anyone may help me?
Davide
__daniel.lincoln__
There is a way to do it using Varjo Lab Tools software and creating/applying Masks.
https://developer.varjo.com/lab-tools#masking
d.barboni
Thanks Daniel,
I know this solution, but i know that in unity and unreal there is the possibility to make a surface with material with rgba (0,0,0,0) that make a hole and attach this surface to a marker.
In this way this hole is dynamic.
sinje_thiedemann
Hi @d.barboni
since version 2023.1, the "Visible in Alpha" (=off) option from the Render Layer module also works in OpenGL, for this MR use case.
Create a layer, add a node (geometry or any parent) from the scenegraph, switch the Visible in Alpha to off, and activate the layer.
https://help.autodesk.com/view/VREDPRODUCTS/2024/ENU/?guid=VRED_Rendering_The_Render_Layer_Dialog_Bo...
Note: Most other options in Render Layer only work in Raytracing.
Kind regards
Sinje
d.barboni
It works!
thanks a lot
Davide
fangty
That's amazing, powerful. Thank you for sharing.
