Variant Set Issue when trying to add multiple switches VRED 27
muz86
muz86
I am starting a new build and am working with a file with hundreds of switches. In order to efficiently begin the build, I selected all the switches using the Scenegraph Filter and select Switch. I then attempted to drag these switches into the Geometry Variant Set area. The trouble is, it only adds the top node switches, so if you have switches within switches, these arent captured.
It seems to only work if I manually go through the scenegraph, manually select each individual switch and drag it into the Geometry Vset. If I try and do multiple Switches, they aren't added.
Bianca.Mutter
Hi Muz86, it would be good to know which VRED version you are working with. We recently released a huge update of the VSet Editor with 2027.1 and your workflow should be perfectly covered. It did not work in the old VSet Editor before 2027.1. Please clarify which version you are in and if you have further questions. Thank you!
