Using multiple tracker to position objects
Message 1 of 1
Hello everyone,
I ´d like to position a digital version of a seating buck so that it aligns perfectly with the physical version of that seating buck when wearing the HMD (HTC Vive Pro).
For this I am using a HTC Vive Tracker. The issue here is that it is very sensitive to the position and rotation of the physical tracker. This issue leads to a big difference between physical and virtual seating buck in position when the tracker is just a few Degrees positioned differently as it should be.
Is there a solution for this Problem, maybe by using multiple Tracker that are located far away?
KR
Replies (0)
