Transform Rotation Pivot Pick 2 Points
stefan_holzingerNA4FN
Hello everyone, I would like to set a rotation axis. If I understand it correctly, I can set the rotation pivot using Pick 2 Points. The axis is then defined by the two points.
I have imported a curve from Catia and would like to set the rotation axis via the two pick points. How can I select the end points or any points on the curve? VRED displays the curve as a tube. When I try to select a point by shift-clicking, it is somewhere on the tube.
What am I doing wrong?
Thank you for your help!
seiferp
(view in My Videos)
It is indeed hard to pick the end points on the line due to it is rendered just with 1px, but possible!
