Texture png changed, while setting up texture in another material
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, i'm struggling with a strange issue while setting up materials textures.
I set up a texture in a new plastic material using one of the 2 png i share (Assembled for Working_00000.png).
Then i make the same in an other material with the other png (Demolition Mode_00000.png)
Going back to the first material i found the last texture (Demolition) and not the one i put.
Doing the same with another png does not make the same, so i suppose it is something related to the 2 images.
Those are created in After effects, them are parte of a png sequence.
Attached a small viso and the png's
How is this possible??
Tested in 2025.0 and .1
Edit...
The frame 00000 of the png sequence is "empty", only alpha channel... could this be a problem?
i ask because selecting the 00001.png, a frame with "something" it does not happen and every material keep his selected texture.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
