Hi All,
I'm working on automation of simple but constant UV set creation on multiple objects (more than thousands).
Some of them need basic Y planar projection fitted to the object and others need cylindrical projection at the center of the object with constant values on rotate and scale.
It's usually something that I made in the texture editor, but the amount of data is to big to make it individualy.
Is there a command for the texture editor ?
I've search in the VRED python API v1 but I didn't find anything that solve my problem.
Maybe it's not only one simple command...
Thanks for any future suggestion.
Guillaume
