Switch Between V-Set with one Touch Sensors
a_melbourne01
a_melbourne01
hello,
I need a way of switching between V-set with just one Touch Senors. Is there a way of doing this with Scripting or another way of doing these that im not aware of?
Thanks Andy
j.kaestle
If I got it right, it should be possible with scripting.
You can define a V-Set for the touch sensor with this Python command:
selectVariantSet(V-Set-Name)
where V-Set-Name is a variable with the Name of the V-Set you want to call. The Name can be defined by some other Code. So it's possible to call different V-Sets with one Touch Sensor. E.G. by iterating a list with V-Set Names.
Hope this helps
Regards Jochen
a_melbourne01
Hi Jochen,
Thank you for getting back to me.
I`m complete new to scripting do you have an example of what the script would look like to achieve these?
Andy
guillaume_juif
Hi Andy,
I'm not an expert in python, but something like this in a variantSet can do the trick
listLengh = len(VSetList)
if i < listLengh:
    vSet = VSetList[i]
    print vSet
    selectVariantSet(vSet)
    i = i+1
elif i == listLengh:
    i = 0
    vSet = VSetList[i]
    print vSet
    i = i+1
it's probably not clean
and you add this to your script editor
VSetList = ["Variant 1", "Variant 2", "Variant 3"]
i = 0
just replace by your variantSets names and add some if you need.
Hope it can help
a_melbourne01
Thank you,
That works great. The only problem that im having is that the first time i use it when opening my file, it takes along time to work then after the first time it works great. Im having the same problem with all the script i run.
Do you know of any good website to learn about scripting in Vred? I want to get my head around it but i have no idea where to start.
Andy
guillaume_juif
Strange, I don't have any problem with it.
Try to open the simple scene i've join and execute the New Variant 1 to see if you have Variant 1 2 or 3  return in the Terminal.
If it works great at first execution, it probably come from you data.
a_melbourne01
Hi Guillaume Juif,
Thank you again for your help with the variantSet script, i have another question tho. If i need to used it more then once in a scene, what will i need to change in the script so it can recognize the different lists?
Thank you,
Andy
