Shadow map changes
Shadow map changes
Shadow map changes
I'm using Vred Prof. 2020.0.
Under statistics the "shadow map changes" is always increasing? What is the reason for this?
michael_nikelsky
A shadow map change happens when anything in the scene changes that requires to rebuild the shadow maps. Usually this is a moving objects or something like that but a flawed script might also trigger it. But usually you can just ignore it since you mostlikely can´t do much about it anyways.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
Thank you Michael,
I just ignore it because there isn't any moving objects or any scripts, may be only the thing that the file is an old file that has been updated with several Vred versions. So I guess there is a bug.
