Substance Car Reflector Lights Material
It's my first time using VRED and Substance Source. The problem I am having in particular is with the material 'Cataphote Rear Wave Dents' for the side lights of the car. When downloading and applying the material to the part VRED says that it's ignoringn unsuppourted normal backface. With the part not representing anything it should look like. Anyone else had this problem?
Jack
seiferp
VRED does not support MDL Materials that are created with Substance Designer!
sinje_thiedemann
To explain what the message means:
Ignoring unsupported Substance normalBackface channel of pkg://cataphote_rear_double_triangle.
It means that the loaded sbsar contains a special texture channel (which is called "normalBackface" in this case), that VRED cannot read. This file has 2 normal textures. VRED only reads the "normal" channel.
Here's a list of all channels that VRED can read from sbsar files: http://help.autodesk.com/view/VREDPRODUCTS/2020/ENU/?guid=VRED_Materials_About_the_Substance_Attribu... (Supported Texture Channels)
Thank you so much for getting back to me, that has helped so much 🙂
