Still some problems with vrOpenVR.vrOpenVRController
marc.winter2
marc.winter2
i had some problems with vrOpenVRController in older VredVersions but with VredPro 2020.3 it has changed. There is now no teleport function in vr any more after executing following script which creates the controller and connects to moved-Signal. HTC-VivePro with viveControllers
from functools import partial
def controllerMoved(_name, _ctrl):
    tempMatrix = _ctrl.getWorldMatrix()
    if tempMatrix != [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]:
        print _name + ' ' + str(_ctrl)
tempcontrollers = dict()
tempcontrollerNames = ['GenericTracker0', 'GenericTracker1', 'GenericTracker2', 'GenericTracker3', 'GenericTracker4', 'GenericTracker5', 'GenericTracker6', 'GenericTracker7']
for tempControllerName in tempcontrollerNames:
    tempController = vrOpenVR.vrOpenVRController(tempControllerName)
    tempcontrollers[tempControllerName] = tempController
    tempController.connectSignal('controllerMoved', partial(controllerMoved, tempControllerName, tempController))
Something wrong with the script?
Best regards,
Marc
Christian_Garimberti
If you want to use old and new api and functionalities, you have to activate the new service at the end of your script, or at least after the old api's like vrOpenVR.vrOpenVRController.
vrImmersiveInteractionService.setDefaultInteractionsActive(True)
If you use old api Vred disable new features, so you have to enable it.
Could you try?
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
marc.winter2
Hi Chris,
finally i found the time to touch this again.
I have switched to the new api. Which solved the problems.
Now i have new problems and much more possibilities.  😄
I will take a deeper look.
Thanks you.
Best regards Marc
