Hi All,
Is there a way to set the origin (e.g. ORIGIN_WORLD, ORIGIN_HEAD) for the default Immersive Tools Menu? This can easily be done for an object of the vrdImmersiveMenu class, e.g. when one creates a custom menu with vrImmersiveUiService.createMenu(). Maybe the default Tools Menu is also an object of this class, if so is there a way to reference it?
Eventually I would like to implement a function to detach the Tools Menu from the controller in order to allow for single controller menu operations.
Thanks in advance!
- Florian
Solved by __daniel.lincoln__. Go to Solution.
