VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Reset Variant Set with python
7 REPLIES 7
Message 1 of 8
lbs_markus_s
1046 Views, 7 Replies
i have a variant set with some Clips in the animation tab. Ist a sequential Animation. With a touchsensor you can play one Clip after another.
So how can i reset the variant set if i'm in the middle of all Clips and want it to start with the first one again
Thx
7 REPLIES 7
Message 2 of 8
dlincol1
in reply to: lbs_markus_s
Create another Variant Set to reset the clips.
e.g. resetAnim('Clip1'); resetAnim('Clip2')... in Script tab
Dan
Message 3 of 8
lbs_markus_s
in reply to: dlincol1
Hi Dan,
i know about that but this is not really working for me.
for example if you have a variant set with 2 Clips ..open and closing a door
variant set open/Close
clip1 = open
clip2 = Close
so if someone is clicking trough the animations with a touchsensor and the door is left open .. you want to reset the whole Scene and all doors are closed before a second person starts with this Scene
so you can use a second variant set to Close all doors, but in our first variant set open/Close the next clip will be Close the door. So if the door is already Closed and you click the touchsensor again it Plays the closing Animation again.
Message 4 of 8
dlincol1
Ok, I see what you mean.
There needs to be a way to reset the VSet sequence.
I'm not sure how to access that.
Dan
Message 5 of 8
You also can keep track of your variant execution yourself.
Something like that:
door_open variant script: door = True
door_close variant script: door = False
door_toggle variant script: if door: selectVariantSet('door_close') else: selectVariantSet('door_open')
reset variant script: selectVariantSet('door_close')
Cheers,
Janosch
Message 6 of 8
seiferp
Hi Markus,
the attached example is also using python in the VSets and checks the "if" state before playing the close door animation. Hope this helps.
Cheers
Pascal
Message 7 of 8
lbs_markus_s
in reply to: seiferp
Hi Pascal,
thank you very much. It is definitely a way to solve the Problem.
Thx
Markus
Message 8 of 8
seiferp
Smiley Happy Awesome
