Getting python errors in versions SR1-SP1 and SP2 for example scripts: 'camera-fixed-object.py' and 'camera-fixed-object2.py'
Left image is 2015 SP1(no errors), right image is 2015 SR1-SP1
Solved by sinje_thiedemann. Go to Solution.
the previous version of findNodePath() also accepted only a node name instead of a node path. It returned the result of findNode then. This has changed since 2015 SR1-SP1. We'll look into that.
Workaround:
Change line
obj = findNodePath("tasse_body")
to
obj = findNode("tasse_body")
Then both scripts should work again.
Best regards
Sinje
