VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
PySide2.QtWebKit not available ?!
5 REPLIES 5
9756 Views, 5 Replies
Enter this code "from PySide2.QtWebKit import QWebView" to VRED 2018.3 (10.11) terminal the result is:
root: from PySide2.QtWebKit import QWebView
Traceback (most recent call last):
File "<string>", line 1, in <module>
ImportError: No module named QtWebKit
Does that mean pyside2 is  limited and can't deal with QWebView (i.e. to emulate a browser) ??
5 REPLIES 5
michael_nikelsky
QtWebkit is deprecated and therefore no longer supported. You should use QWebEngine instead: http://doc.qt.io/qt-5/qtwebenginewidgets-qtwebkitportingguide.html
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
in reply to: michael_nikelsky
Hmm??
I'm not sure what you mean with: use QWebEngineView?!
In fact this doesn'r work either:
root: from PySide2.QWebEngine import *
ImportError: No module named QWebEngine
michael_nikelsky
it should be
from PySide2.QtWebEngineWidgets import QWebEngineView
For example:
from PySide2.QtCore import QUrl
view = QWebEngineView()
view.load(QUrl("https://wiki.qt.io/PySide2"))
view.show()
Kind regards
Michael
Michael Nikelsky
That's a big progress !!!
But I have still some strange problem:
This code works fine:
# -*- coding: utf-8 -*-
import sys
try: # Version 2018+
except ImportError:
   print "Uuups, can't import all needed stuff"
if __name__ == '__main__':
   view.show()
But the folowing code doesn't show anything !!! ????
import sys
except ImportError:
def run():
   view.show()
   run()
So question: What's wrong with that???
sinje_thiedemann
The view object you create in run() goes out of scope at the end of run, so the widget is deleted again and you don't see it.
Move the code from run() into a class:
import sys
except ImportError:
class View:
    def __init__(self):
       self.view = QWebEngineView()
       self.view.load(QUrl("https://wiki.qt.io/PySide2"))
       self.view.show()
   view = View()
Kind regards
Sinje
