How can I set planar projection for glass materials? From what I have seen only triplanar projection is possible.
Thanks you in advance,
Michele
Solved by seiferp. Go to Solution.
You can set the material to UV and project planar on the object in the UV Editor... maybe?!
Now I try. My problem is that I need to script the position of the texture and using the planar mode is quite convenient.
