performance impact of image format?
MarkusSchnabel1921
MarkusSchnabel1921
Hi to all,
I wonder if the image format in which i load shaders with uv projection has an impact on the performance of the scene? I use .png having images with 8k and even 16k resolution.
thanks
regards Markus
michael_nikelsky
The file format does not matter, only the pixel depth is relevant. So whether you use JPGs or PNGs does not make a difference while using 16 bit vs. 8 bit does.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
