![](/skins/images/635B002DB41BB0458E3712361FD4C908/responsive_peak/images/icon_anonymous_message.png)
01:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
a viewpoints eulerRotation override does not refresh.
vp_node.fields().setVec3f("eulerRotation", angles[0],angles[1],angles[2])
selectViewPoint(vp_name)
The values are overridden when I open the Nodeeditor, but even if I manually select the viewpoint, the view doesn't change.
Doing the same with "translation", works
overriding the matrix doesn't work either.
I'm using 2017.2. Is that a bug or do I have to trigger something?
Thank you for any help
