With the new teleport function in the 2019.2 i can go over objects, if selected the correct option.
But if the object is higher the me, in vr i mean, the teleport doesn't work (red ray appear).
any suggestion?
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Solved by seiferp. Go to Solution.
Hi Christian,
this behavior is by design. We are using a single ray approach with a fixed teleport arc. If you want to teleport on a 2nd or higher level you must use helper objects like stairs or use pre-defined viewpoints you can jump to. Esteregg: you can also teleport on your vr menu!?!
Thank you.
With stairs is very realistic, with other object is more like "parkour", but it works.
Using viewpoints is very easy to setup, but i think is more complex for the user "first use".
Bye
Chris
